rear disk brake conversion problem
24 Mar 2022 10:29 #242469
by safari
if u worry u die if u dont worry u still die so why worry
rear disk brake conversion problem was created by safari
a friend of mine just fitted the rear disk brake but is having problems breaking is not very good if not worst compared to drum .
car is fitted with 31" tyres
what to look for to solve the problem pls
- Thank you received: 115
24 Mar 2022 12:37 #242474
by maverick
Jalapeño, IISY?
Replied by maverick on topic rear disk brake conversion problem
Where did you get rear disk brake from?
Jalapeño, IISY?
24 Mar 2022 13:31 #242475
by safari
Replied by safari on topic rear disk brake conversion problem
he bought it ready but seller told him jimny bits
- Roger Fairclough
- Thank you received: 225
24 Mar 2022 14:59 #242479
by Roger Fairclough
Replied by Roger Fairclough on topic rear disk brake conversion problem
Sometimes the calipers sold with these kits has the bleed nipple on the down side to the fluid entry point. If so you need to remove the caliper and twist it to get the the nipple upwards. This is if you have a hose connecting caliper to pipe. If this is not the case, you have a problem.
Roger
Roger
Time to create page: 0.176 seconds
