New engine noises!
4 years 7 months ago #242544
by me101
2007 Little Jim with cheap mods!
www.youtube.com/channel/UCeBDekO99Qk2aOmBmSmrI9w
Replied by me101 on topic New engine noises!
Thanks, I'm in Doncaster. Back at work now, so will be leaving it for a few days now unfortunately. Cheers
4 years 7 months ago #242592
by me101
Quick question, the more I sit at work thinking about it, I am going for input shaft bearing as all noises go away with clutch pressed. The bearing looks cheap enough, but regarding man hours, is it going to be cheaper to replace the gearbox?
- Roger Fairclough
- Thank you received: 225
4 years 7 months ago #242597
by Roger Fairclough
Replied by Roger Fairclough on topic New engine noises!
Replace the box with what? A new one will be an arm and a leg and reconditioned will be £500 plus and a s/hand one could well be as bad. Best bet is to replace the bearing. On my Gen.2 SJ413 I did 150,000 miles and changed that bearing a number of times. I did a lot of green-laning and RTV competitions so the box was used hard.
Roger
Roger
4 years 7 months ago #242619
by me101
Is it not a box apart job? Gearbox is one of them things I just don't want to get too deep into!
- Roger Fairclough
4 years 7 months ago #242621
by Roger Fairclough
Yes it is but its not a major issue. OK I'm speaking from the position of a trained technician which I realise makes a big difference and the probability is that if you have any doubts then talking to a few independent technicians is the way to go. It would keep the cost down if you removed the box yourself and as it is a separate item from the transfer box it is not that heavy. Certainly an average guy, working on his own, can remove the box. If you want to go this route, then there are plenty of guys on this forum who can help you.
Roger
Roger
4 years 7 months ago #242629
by me101
Thanks, I'll take it out and then decide if I'm brave enough to tackle myself. Will it do much harm running as it is for a while?
