Need advice for 02 plate front axel replacement
16 Mar 2022 19:21 - 16 Mar 2022 19:23 #242352 by Lambert
The MOT advisory states: nearside front swivel ball leaking.
That's ok then. All you need is a kingpin rebuild kit from Martin in the shop in the top banner. This is the two bearings that will have undoubtedly failed which in turn have caused the inner axle oil seal (included in the kit) to allow axle oil into the swivel which bypasses the outer dust seal. There's a full how to in the information section. You don't need to replace the axle or write off the car. The kit is cheap and the job can be done by a competent amateur in half a day.
Last edit: 16 Mar 2022 19:23 by Lambert.
16 Mar 2022 19:24 #242353 by gv42
I'd second the above
16 Mar 2022 21:35 - 16 Mar 2022 21:37 #242356 by Scimike
I'll third the above.
I'll also add that any replacement axle is likely to need this work anyway. It's an easy job, get the parts from Martin (Big Jimny Shop) and follow his excellent "how to video".
Last edit: 16 Mar 2022 21:37 by Scimike.
17 Mar 2022 08:55 - 17 Mar 2022 08:55 #242358 by Busta
It's quite common for well-meaning mechanics to completely fill the inside of the swivel with grease, and in the absence of an adequate seal to retain it this will leak out. So as Roger says, first step is to clean it up and hope it stays clean for the MOT. I wouldn't rush to change kingpin bearings unless you get movement in the swivel or the characteristic wheel wobble.
And it certainly isn't in need of an axle replacement! On a Jimny a rusty swivel is a healthy swivel.
Last edit: 17 Mar 2022 08:55 by Busta.
17 Mar 2022 09:20 #242360 by Lambert
Either way it's going to need some intervention either to clean excessive grease or to replace bearings and seals.
17 Mar 2022 10:33 #242361 by mlines
As Busta says, its very common where the Engineer is used to Land Rovers.
Old LandRovers required the Swivel Joint to be filled with oil. Suzuki requires them to be "dry" with only 100g of grease IN TOTAL.
When such an Engineer sees leaking oil they think the worst from their LandRover experience and expect to change the Chromed Balls like a Landrover. The Suzuki balls are built into the axle so they immediately suggest changing the axle.
Instead all it needs is a simple Kingpin Bearing change. The worn bearings are causing wobble in the driveshaft that is letting diff oil to leak past the small internal seal and then leak out onto the road.
Its a straight forward bearing change, less than 2 hours work for an Engineer (I can do both sides in an hour now I have practiced a lot!)
Time to create page: 0.200 seconds
