No check engine light during ignition
  • Jimnyfan5
07 Mar 2022 07:05 #242172 by Jimnyfan5
Replied by Jimnyfan5 on topic No check engine light during ignition
Yes I am familiar with a volt metre. I have quite a few other jimnys so parts are easy to come by.. the ecu wasn’t my first call.. I’ve swapped relays and all sorts of dash computers.. if I could get pointed in the direction of some wires to check for volts or connections anywhere that have known to fail then I
Can check them
07 Mar 2022 14:13 #242179 by fordem
It sounds like your approach to solving the problem is to simply swap whatever parts you have handy and hope for the best - certainly not how I would chose to deal with it.
The first thing I would be checking for is 12V power at the main relay
  • Jimnyfan5
10 Mar 2022 07:19 #242216 by Jimnyfan5
And after that? Have you a wiring diagram of main relay? Where barrel ignition goes? What wire powers the computer etc
10 Mar 2022 17:25 #242227 by fordem
I might be able to find something if I had the details of the vehicle - or if you let me know whether or not these was power to the main relay.
And whilst I'm about it - I have a strong feeling that there is a back story to this saga that we haven't heard yet.
  • Jimnyfan5
20 Mar 2022 06:47 #242408 by Jimnyfan5
It’s a 1999 Suzuki jimny. I haven’t checked yet if there is power to the main relay. No back story. I purley put new gloves in went for a drive forgot to turn lights of then battery went flat got in tried to start it nothing the. Charged battery chucked it back in and it cranks but the engine light doesn’t come up on dash during ignition and the fuel pump isn’t priming.. it’s got no immobiliser so I know that’s not the problem..
20 Mar 2022 16:23 #242413 by fordem
Let me know what you find when you check for power at the main relay...
