Internal diameter vacuum hoses
- thieuster
11 Feb 2022 23:51 #241799
by thieuster
Internal diameter vacuum hoses was created by thieuster
I'm about to replace the vacuum hoses. I've read here 'internal diameter = 3mm', but I've also seen a posting mentioning 4mm.
What's the correct size?
Menno
Menno
12 Feb 2022 08:57 #241807
by LesNewell
Replied by LesNewell on topic Internal diameter vacuum hoses
The metal tubes are 4mm outside diameter. The rubber hoses are 4mm inside so they push over the metal tube.
If you have rusted out tubes, you can buy 4mm nylon tube pretty easily as it's widely used in industry. You can also get 4mm plastic push-fit fittings in all sizes and shapes. You need two push fit tees to split the tubes out to each hub. There are lots of sellers on eBay. That's what I used on my Jimny.
- thieuster
12 Feb 2022 13:24 #241821
by thieuster
Replied by thieuster on topic Internal diameter vacuum hoses
Thanks for the answer!
Menno
Menno
Time to create page: 0.260 seconds
