Jimny Transfere case
  • 8ollins
10 Feb 2022 21:42 #241778 by 8ollins
Jimny Transfere case was created by 8ollins
Evening,
I have a 2007 Jimny Manual with the push-button electric transfer case. Shifts into 4wd-high every time. It used to shift into 4wd-low but has been just on the road for a few months so I haven't needed it for a while and I now find it won't do so. Tried rolling it very slowly and shifting but did nothing. Any suggestions are appreciated. Thanks!
10 Feb 2022 23:03 - 10 Feb 2022 23:04 #241781 by yakuza
Replied by yakuza on topic Jimny Transfere case
Had the same on mine, but it has thrown a fit and come out of it so work fine now. I was planning to Try to lubricate the actuator on the transfer.
Does the 4wd light blink or show a steady light when in 4 high mode?
Should be steady.
Does it beep and blink when you Try to engage  4 low?
Last edit: 10 Feb 2022 23:04 by yakuza.
11 Feb 2022 05:26 #241784 by Lambert
Replied by Lambert on topic Jimny Transfere case
It also probably worth checking the wires in and out of the transfer case for damage.
Time to create page: 0.147 seconds
