Jimny floor pan
  • MafiaMemes
4 years 10 months ago #241126 by MafiaMemes
Jimny floor pan was created by MafiaMemes
Hi, does anyone know what my chances are of finding the driver and passenger side floor pan to be able to weld in? Can't find anything anywhere for some reason?
Thanks
Alex
4 years 10 months ago #241137 by Scimike
Replied by Scimike on topic Jimny floor pan
I have not seen anything myself, but a couple of routes spring to mind.
First ask Martin via the shop if he can get anything from Suzuki. If it's a no the I suspect used may be the next option, cut a panel from a scrap vehicle. Obviously you need to be sure it's in good condition, but it's not impossible to use a bit from a donor vehicle.
Good luck
The following user(s) said Thank You: MafiaMemes
  • Dirtbird
4 years 10 months ago #241232 by Dirtbird
Replied by Dirtbird on topic Jimny floor pan
there is a driver on here called Green turtle or the project was named green turtle and he welded a lot of his floor and it looked fine. Having said that and done some welding on mine getting the floor out of a good doner would be far easier to do than trying to fab sheet metal but can be done .
  • MafiaMemes
4 years 10 months ago #241278 by MafiaMemes
Replied by MafiaMemes on topic Jimny floor pan
Thanks a lot for the replies guys. Will call up suzuki but then most likely end up fabbing them.
