Open Door Light
02 Jan 2022 08:20 #240884 by PeterH
Open Door Light was created by PeterH
The warning light showing an open door on my 2013 Jimny is faintly glowing all the time with all the doors closed. I've opened and closed all the doors but it always goes back to a very faint glow.
Any ideas?
02 Jan 2022 10:57 #240885 by RainerK
Replied by RainerK on topic Open Door Light
This could be the door switches and they are easy to check. As a first step, I would remove them one by one and check if the light goes completely off.
Then I would check the power consumption of the car when it is turned off. Just to make sure that you do not drain your battery.
The next step would be to remove the (relevant) fuses, maybe this gives some information.
And as a last step, I would remove and, if possible, check the instrument cluster.
The following user(s) said Thank You: PeterH
04 Jan 2022 18:08 #240901 by PeterH
Replied by PeterH on topic Open Door Light
Thanks.
Rear door switch was damp. Quick squirt of WD40. Light now out
Time to create page: 0.137 seconds
