2003 without fog lights , upgrade
17 Dec 2021 17:40 #240702
by LM42
2003 without fog lights , upgrade was created by LM42
need some help! Going to use the front fog light wiring to run a Extra rear reverse light , got the switch fitted to the loom, but the light in the switch works when you enable it, but no output from the connector in the engine? Guess the relay is missing, where would it be? ( Fitted the fuse )
Sent from my Redmi Note 8T using Tapatalk
18 Dec 2021 10:47 #240706
by Scimike
Replied by Scimike on topic 2003 without fog lights , upgrade
Possibly no help at all but posted In the spirit of trying to help.
In a 2009 its the fuse box under the bonnet, strangely I can't determine which relay is switching using my stethoscope and reluctant to start pulling things out as it works (don't mess with a runner). If 2003 / 2009 have same fuse box hopefully you cs spot the missing relay in the photo.
The following user(s) said Thank You: LM42
18 Dec 2021 11:24 #240707
by Bosanek
Replied by Bosanek on topic 2003 without fog lights , upgrade
If you do find out something new and useful during your trials, please contribute to this wiki article:
www.bigjimny.com/mediawiki/index.php/Front_fog_lamps
19 Dec 2021 01:17 - 19 Dec 2021 01:59 #240713
by fordem
Replied by fordem on topic 2003 without fog lights , upgrade
First - there's like a 99% probability that the relay was never fitted, if the fog lights were never fitted, the switch & the relay aren't going to be fitted either.
Second - the front fog light wiring goes to the front of the car, and the reverse lights are usually at the rear, making the front fog light wiring a poor choice to "re-purpose".
It would be a lot simpler to tap into the existing reverse light wiring which is already at the rear of the car, and unless you're attempting to run something like a 50w fog/spot light as a reverse light, will be more than capable of handling the load.
Personally, if I were fitting an additional reverse light, I'd be using a small LED lamp, probably no more than 18W or thereabouts.
As far as I can tell, based on the wiring diagram connector layouts, if the relay is fitted, it'll be under the dash.
Last edit: 19 Dec 2021 01:59 by fordem. Reason: additional information.
19 Dec 2021 10:47 #240714
by LM42
Replied by LM42 on topic Re:2003 without fog lights , upgrade
We repurposed the front fog light switch to run independent rear "reverse light" , will carry on looking thank you all for the information
19 Dec 2021 12:29 #240715
by fordem
Replied by fordem on topic Re:2003 without fog lights , upgrade
I got the impression from your first post, that you were attempting to re-purpose the front fog light wiring to run a reverse light, and in the process of doing so, you had fitted the switch and couldn't get it to work - is that correct?
What I said earlier about the choice of wiring will still hold true, even if you choose to switch the light independently.
You might want to check vehicle lighting legislation wherever you are on the legality of independently switched reverse lights, I suspect having a rear facing white light on whilst the vehicle is being driven may be "frowned upon".
Incidentally - the front fogs on my car are switched by what was once the rear fog light switch - front fogs were not an option in my market, rear fogs were, the vehicle came with neither, but I purchased the switch, fitted it and reused nothing from the wiring other than the connector that the switch plugged into - sort of the reverse of what you're attempting to do.
I'd suggest if you don't have the know how to build your own reverse light harness, that you buy an aftermarket spot or fog light harness and adapt that to suit your needs. I'd also suggest that you "tie" it in to the existing reverse light wiring so that you can have the additional light off when the original reverse lights are on, but it cannot come on when they are off - something that can be done by adding one switch and the necessary wire.
