Windscreen washer jets
28 Nov 2021 14:49 #240364 by JAGtheman
Simple question (but I gather this can fail your MOT?): Gen 3, pax side windscreen washer jet on my jimny just sprays 1 jet of water. My question: should both jets shoot 2 streams of liquid each?
Julian
2008 Gen 3 Manual
Being completely revitalised
28 Nov 2021 15:57 #240366 by Lambert
Replied by Lambert on topic Windscreen washer jets
Yes they should but I could not get Dreadnaught to do it on one of the passenger ones because it became blocked with some kind of slime goo. The council test centre weren't overly bothered so long as some water was available to wash the screen.
28 Nov 2021 16:07 #240367 by fordem
Replied by fordem on topic Windscreen washer jets
Doesn't a bit of fine stiff wire usually solve resolve this?
I'm not certain about the UK, but in the US, the auto parts chains have universal nozzles (not the gaudy multi-color LED ones) that I've used on a couple of different Suzukis after the original got damaged.
28 Nov 2021 16:43 #240368 by Roger Fairclough
Air jet works for me but disconnect water delivery hose and direct air into the small round direction jets.
Roger
28 Nov 2021 19:30 #240374 by HUN
Replied by HUN on topic Windscreen washer jets
Alternatively replace them with this:
www.lambertsengineeringltd.co.uk/suzuki-...uirter-water-nozzles
TrailMaster 2" lift kit
ORE transfer box HD brackets
T-Max split charge system
Flo-Flex castor polybushes
Kumho KL71 tyres
AVM manual hubs
ORA radius arm guards
Push-fit breathers
28 Nov 2021 19:32 #240375 by JAGtheman
Replied by JAGtheman on topic Windscreen washer jets
Thanks to all for replying. I am loath to stick something into the hole as I will most likely damage it so first I will disconnect the feeder pipe and use a tyre pump to "blast" through the jets in the same direction as water flow and see if that works. Or engine degreaser to dissolve some gogga that crawled into the pipe? If that fails, then I will try with fine copper wire and hopefully will neither damage the hole nor alter the direction of the spray.
I have seen this in MoT reports when I was searching for my Jimny and will be mega unhappy if my MoT reflects this after all the work I have put in to make this Jimny rock solid.
Thanks again all!
Julian
2008 Gen 3 Manual
Time to create page: 0.158 seconds
