Front shocks
  • Jambls
17 Nov 2021 14:56 #240156 by Jambls
Front shocks was created by Jambls
Hi folks, I'm needing new front shocks after doing MudMaster, but I don't have a lift and all I can find at standard length are aftermarket brands. Which one should I go for, or are there some to avoid?
Ta
17 Nov 2021 15:27 #240158 by Lambert
Replied by Lambert on topic Front shocks
Monroe are very good as are KYB. The other alternative is something like trailmaster either comfort or sport but they are big body dampers and expensive especially as you would need all 4.
The following user(s) said Thank You: Jambls
17 Nov 2021 17:25 - 17 Nov 2021 17:25 #240160 by Scimike
Replied by Scimike on topic Front shocks
Hi I can't recall any discussions about shocks to avoid, so I guess it's down to what features you want from them.
Monroe have always been good for me also, still are on my 2CV, now that's a car that works the dampers hard
I have also had good results with Koni, my Jimny runs a set on the rear, fitted for towing. When the OEM fronts fail that's what I will fit again so they are all matched.
Last edit: 17 Nov 2021 17:25 by Scimike.
  • Jambls
18 Nov 2021 21:33 #240192 by Jambls
Replied by Jambls on topic Front shocks
Thanks for the help, monroe sound like just the ticket. Hopefully changing them won't be too bad, but we'll see.
