Spark plug choices?!
- Thank you received: 667
14 Nov 2021 19:14 #240124
Replied by DrRobin on topic Spark plug choices?!
Most plug gaps are pretty much spot on these days, the vehicle manufacturer pretty much goes with the plug manufacturer's standard gap.
Just as well as on my other car the plugs have 3 cathodes arranged around the central anode, I wouldn't want to start trying to gap those, I don't think you would ever get them all the same.
The following user(s) said Thank You: Waffs1984
10 Nov 2023 02:27 - 10 Nov 2023 02:29 #252045
by Miownway
2022 JB74
K15B w/ snorkel
XTREME OUTBACK stage 1 clutch
Warn VRX 4500 winch
235/75R15
Replied by Miownway on topic Spark plug choices?!
I have read that NGK has an upgraded spark plug from the Premium RX to the Ruthenium HX. I can not find a cross-reference between the two. The specs for the Premium RX (DCPR6ERX-11P / 90558) are: Thread diameter: 12mm Thread reach: 19mm Seat type: flat Hex size: 16mm
Is there a Ruthenium HX model that matches this spec?
Or, am I way off with my understanding about these?
2022 JB74
K15B w/ snorkel
Warn VRX 4500 winch
235/75R15
Last edit: 10 Nov 2023 02:29 by Miownway. Reason: Format
- rogerzilla
10 Nov 2023 09:26 - 10 Nov 2023 09:28 #252052
by rogerzilla
Replied by rogerzilla on topic Spark plug choices?!
I fitted the Denso iridium ones. A bit cheaper than NGK and I found a marginal improvement in mpg with them in other cars.
I don't know if Denso supply Suzuki but they supply a lot of OEM parts on Mazdas etc.
Last edit: 10 Nov 2023 09:28 by rogerzilla.
10 Nov 2023 15:38 #252058
In 2021 I bought a set of NGK Iridium IFR6J11, 4 for £52 for my 2011 Gen3. I fully expect them to last the life of the car, but if they do need replacing it won't be the tip that has worn out, it will probably be oil fouling or some other type of damage.
Iridium are meant to be good for up to 100k miles.
Ruthenium tip are meant to last longer and give slightly higher performance, whilst this might be true of a modern car engine where fuel efficiency and performance is much higher I doubt it will make any difference at all to a Jimny.
The longer electrode life will be of limited benefit as something else will wreck the plugs, like oil fouling, over-heating or muck and dust on the outside so I doubt you will see any benefit.
However, see how much they are and if they are about the same price as Iridium (or cheaper) then go for it, just don't expect to notice any difference over a decent set of ordinary or Iridium plugs.
By the way I couldn't find any for sale in the UK to fit a Jimny, there seemed to be some in Japan though.
Robin
Robin
10 Nov 2023 16:06 #252060
by Busta
Replied by Busta on topic Spark plug choices?!
Don't overthink spark plugs. All Jimnys have very basic, low performance engines. The only benefit of more expensive plugs is lifespan, but that is reflected directly in the cost. And if you don't change your plugs for a decade, you may find them reluctant to come out which can lead to much bigger issues. I use standard copper plugs in my Jimnys. They are £20 a set and look good as new after 2 years/20,000 miles.
Time to create page: 0.223 seconds
