Any auto gearbox experts here?
12 Nov 2021 18:13 #240050 by Lambert
This new diagnosis tool,does it happen to show transmission temperature?
12 Nov 2021 18:22 #240051 by LesNewell
Yes it does. In my case it was 82C just after a drive.
12 Nov 2021 18:47 #240052 by Lambert
Useful. Thanks.
13 Nov 2021 21:00 #240083 by LesNewell
As a reference point, driving on the road saw around 100 - 105C, which as far as I can find out is on the high side of normal for an auto box. Most sites seem to quote 175-225F or 80-107C as normal. If you get one of these it would be interesting to see what temperature yours runs at.
13 Nov 2021 21:12 #240084 by Lambert
It arrived today, sat on the drive just back from a good run it was saying 84 ish. I will be looking tomorrow at an actual running temperature, however that will be solo which is good for a base I'm more interested in it with a trailer on the back.
14 Nov 2021 08:29 #240090 by Lambert
Ok so I have just come for mcbreakfast which is 7 or 8 miles of mixed drive before I go to work and in that time engine temperature got up to a fairly stable 88c and transmission was just nicely creeping up to 60c with plenty of air flow from a maximum speed of 96km actual or 60mph indicated. I would expect the transmission to get a bit higher as more heat soaking occurs when I'm going round the sheep but it's not setting off any undue concerns so far.
Time to create page: 0.373 seconds
