Baleno on jimny
12 Oct 2021 05:24 #239330 by safari
Baleno on jimny was created by safari
Have just installed a 16 baleno on my jimny but is not starting and firing what should I check first ?
if u worry u die if u dont worry u still die so why worry
12 Oct 2021 06:20 #239331 by Lambert
Replied by Lambert on topic Baleno on jimny
Double check that all the electrical connectors and earth points are correctly installed and making contact. After that it could be a number of things so it's best to systematically check the fuel system, ignition system and inlet and exhaust system. Its a matter of being methodical.
The following user(s) said Thank You: safari
14 Oct 2021 11:23 - 14 Oct 2021 11:25 #239402 by safari
Replied by safari on topic Baleno on jimny
Thanks for the help it was a timing problem and faulty injectors
Last edit: 14 Oct 2021 11:25 by safari.
