Engine management warning light
5 years 1 week ago #239874 by JAGtheman
A few weeks later: After standing for 3 weeks ( in workshop being derusted and having the underside sealed) and me away in Munich, on my return... slight rough running and the EM light came on, as you all said it would.
I have received my diagnostic tool (V311 OBD2) and found the OBD2 port (drivers side, under dash, right hand side) and diagnosed sporadic cylinder misfire on all cylinders. Lots of other info too, but that is for the weekend when I will look and learn. So the Jimny is booked into a garage next week to see what gives. My hopeful feeling is that the Wynns engine cleaner has loosened gunk which has affected the fuel injectors. Lets see.....
Julian
2008 Gen 3 Manual
Being completely revitalised
5 years 1 week ago #239875 by DrRobin
A tired battery can cause a weak spark and lead to rough running, especially if something else is on the way out (like coils/plugs) so if it has been stood for a while, I I would charge your battery and see if some of the codes will clear?
If the misfire goes, it might suggest coils or plugs are ageing, look for cracks in the coiul packs.
5 years 1 week ago #239966 by JAGtheman
You were absolutely correct: spark plugs and coil need replacing. Being done for me as we speak. Will get the vehicle back tomorrow and go for long run on the weekend. I hope the dreaded EML does not come on again!.
Julian
2008 Gen 3 Manual
5 years 1 week ago #239967 by DrRobin
If you did have a weak spark, new coils and plugs will not only get rid of the EML, but it will feel like a different car.
Time to create page: 0.081 seconds
