Re:Gen 3 rear lights
17 Sep 2021 07:11 #238698 by JAGtheman
Gen 3 rear lights was created by JAGtheman
Morning people.. still getting to grips with my new acquisition, living in Munich & working in the UK stifles my available time to play, next week we are off to a workshop armed with a needle scaler to tidy up the underside, but I have a more mundane question regarding the operation (or not) of the rear light clusters.
When I switch on the headlights, then the fog lights, then activate the right hand most button in the light switch cluster (the one above the "OFF" button) on the dash, the lower red light of the 3 lights in the rear, right hand side vertical light cluster works. The same light on the left does not light up. So, from behind, with the fogs on, there are the 2 normal rear lights on in the bumper, but only one on the right hand side on the vertical rear light cluster.
Is this how it is meant to be or is the bulb on the left vertical cluster kaputt?.
Vehicle is a 2008 JLX+ hardtop...
Vielen dank, baie dankie and thanks..
Julian
2008 Gen 3 Manual
Being completely revitalised
17 Sep 2021 09:25 #238704 by Lambert
Replied by Lambert on topic Gen 3 rear lights
Hi yes that is normal, only one rear fog light.
17 Sep 2021 09:40 - 17 Sep 2021 09:40 #238705 by lookonimages
Replied by lookonimages on topic Re:Gen 3 rear lights
Lambert wrote: Hi yes that is normal, only one rear fog light.
100% correct. Only one side.
Last edit: 17 Sep 2021 09:40 by lookonimages.
17 Sep 2021 16:42 #238727 by JAGtheman
Replied by JAGtheman on topic Re:Gen 3 rear lights
Thanks guys, I am aiming for a clear MoT seeing this vehicle has 3 previous clear MoTs and will feel a total chop if something so obvious causes me to fall on my face.
Julian
2008 Gen 3 Manual
Time to create page: 0.091 seconds
