Already 2” Springs?
  • Sean65
5 years 2 months ago #238475 by Sean65
Already 2” Springs? was created by Sean65
Hi. I have just received some new rear damper and was going to fit the spring spacers as per the front. However, on taking the springs off there was no home made spring spacer as I found at the front and the springs are 35 cm.  can i take it these rear springs are already for a 2” lift so do not need the spacers.   Cheers
  • Dirtbird
5 years 2 months ago #238480 by Dirtbird
Replied by Dirtbird on topic Already 2” Springs?
Can you post some pictures Please Sean65
  • Sean65
5 years 2 months ago #238491 by Sean65
Replied by Sean65 on topic Already 2” Springs?
Can fo but of what else exactly. The spring is 35 cm. I just don't know if they are the standard or already 2” lift
  • Dirtbird
5 years 2 months ago #238493 by Dirtbird
Take some pictures of the springs and the spacers. If you can put the springs together in a line so we can look at them.
5 years 2 months ago #238498 by Lambert
Replied by Lambert on topic Already 2” Springs?
It could be that the springs you have in the back are actually front axle springs as they can lift the back upto 40mm ish.
  • Sean65
5 years 2 months ago #238504 by Sean65
Ok. Here goes. The one on the left is as they came off.  The one on the right is what I thought would simply go back on. However, the diameter of the top of the spring is too small for the spacer to fit into.
puzzling.
Time to create page: 0.110 seconds
