road spring position
5 years 2 months ago #238201 by Busta
Replied by Busta on topic road spring position
No idea about colours but this is the setup with standard springs:
Both front springs are the same and are about 40mm longer than the rears. I would suggest these are the middle 2 in your picture.
The 2 shortest springs are for the rear. You will find that one is made of thinner wire and has fewer coils (2nd from right in your picture). This goes on the nearside rear. the other is offside rear.
Don't confuse this with lift kits, where they usually use a longer spring on the OS front.
5 years 2 months ago #238203 by Lambert
Replied by Lambert on topic road spring position
When I was playing with lowering Dreadnaught the two front springs were definitely different lengths?
  • Baloo
5 years 2 months ago #238217 by Baloo
Replied by Baloo on topic road spring position
sounds right to me, the steering box,  the driver, and the transfer box are all on the offside so i would think it would be taller to start with,   has anyone got the length of a  set of springs of the car ?   just to check i havent got a vitara rear by accident
thanks Andy
5 years 2 months ago #238230 by jackonlyjack
5 years 2 months ago #238259 by Busta
I'd say the 2 left springs are Vitara springs. I can see from the pictures that 2 right hand springs perfectly match every pair of standard rear springs I've ever removed from a Jimny, that is both the same length but one with fewer coils and thinner wire. The fronts are always identical unless it's an aftermarket lift (and quite possibly lowering) kit.
5 years 2 months ago #238499 by Lambert
I wish to offer my apologies for misleading the group. I was under Temeraire yesterday and looking at the springs and Busta and Jack are correct the fronts are the same. Also I noticed that the nsf on mine is 1 purple and 1 white splodge.
The following user(s) said Thank You: Busta
Time to create page: 0.103 seconds
