Battery upgrade
  • Danparry
02 Sep 2021 08:58 #238153 by Danparry
Battery upgrade was created by Danparry
I'm looking for a new battery as mine is getting pretty old
I haven't got any big accessories or anything just an Amp for my speakers and I hook up my air compressor when pump tyres up.
Is it worth going to the hassle of a optima battery or just get a standard starting battery
02 Sep 2021 09:27 #238154 by Roger Fairclough
Replied by Roger Fairclough on topic Battery upgrade
I would buy a decent quality standard battery.
Roger
02 Sep 2021 10:28 - 02 Sep 2021 10:30 #238156 by mlines
Replied by mlines on topic Battery upgrade
If you are talking about the standard Gen3 Jimny, perhaps prior to around 2012, then the standard battery is very small indeed.
I would measure around the battery tray and look at the terminal connections you have and then find a bigger battery that will fit. That is what I have done on my Gen3. With the original tiny batteries I found it did not take a lot of winter driving (short runs, lights on, heater etc. on) to deplete the battery.
I got one from Halfords based on measurements etc (ignore Halfords "battery selector").. Halfords are re-badged Yuasa batteries.
Last edit: 02 Sep 2021 10:30 by mlines.
  • Danparry
06 Sep 2021 11:53 #238278 by Danparry
Replied by Danparry on topic Battery upgrade
Thanks
I've found a couple of options now.so I'll do that :)
07 Sep 2021 12:29 #238317 by yakuza
Replied by yakuza on topic Battery upgrade
www.bigjimny.com/index.php/forum/8-my-ji...kuza?start=96#217746
Like in the post over, I did some cutting and welding to the tray so I could fit a more standard width battery. So pleased with it, 75Ah AGM.
No worries with lack of power from it and even with my cold winters, small generator and mostly short drives to recharge, it holds up very well. I sometimes leave the headlights on for working in front of the car for 15-20 minutes, or the LED's at the rear on for hours. Running the ARB compressor to air up and never start the engine to recharge while using the battery. It just goes and goes.
Time to create page: 0.352 seconds
