Front Bump stops removal
  • Dirtbird
16 Aug 2021 21:40 #237617 by Dirtbird
Front Bump stops removal was created by Dirtbird
Lads how do you remove the front bump stops. I've to prep the threaded nuts and the chassis number with a galvanize stop paste tomorrow and the bump stops are the last things I've to remove.
17 Aug 2021 05:28 #237622 by Lambert
Replied by Lambert on topic Front Bump stops removal
It should be a nut and bolt job the rubber part has a large metal hex built in but how much will remain after years of winter roads is debatable.
  • X8GGY
17 Aug 2021 05:30 #237623 by X8GGY
Replied by X8GGY on topic Front Bump stops removal
Grab it and pull / twist it, sometimes with over-centre plumbers type pleirs...
It's all rubber and the top end is mounted into a hole and the oonly thing holding it there is the shape of the rubber at the top, like this -
:lol: couldn't find a photo of one!!!
That rubber "arrow" bit invariably rips off though... :(
  • X8GGY
17 Aug 2021 05:32 #237624 by X8GGY
That's the rear one Lambert ;)
17 Aug 2021 05:57 #237627 by Lambert
Yes of course it is. Senior moment.
17 Aug 2021 06:02 #237628 by Lambert
I have just adjusted the text scale on my phone so I can actually see what I'm trying to read. Getting old sucks.
Time to create page: 0.098 seconds
