Front Bump stops removal
- Dirtbird
16 Aug 2021 21:40 #237617
by Dirtbird
Front Bump stops removal was created by Dirtbird
Lads how do you remove the front bump stops. I've to prep the threaded nuts and the chassis number with a galvanize stop paste tomorrow and the bump stops are the last things I've to remove.
- Thank you received: 2005
17 Aug 2021 05:28 #237622
Replied by Lambert on topic Front Bump stops removal
It should be a nut and bolt job the rubber part has a large metal hex built in but how much will remain after years of winter roads is debatable.
- X8GGY
17 Aug 2021 05:30 #237623
Replied by X8GGY on topic Front Bump stops removal
Grab it and pull / twist it, sometimes with over-centre plumbers type pleirs...
It's all rubber and the top end is mounted into a hole and the oonly thing holding it there is the shape of the rubber at the top, like this -
:lol: couldn't find a photo of one!!!
That rubber "arrow" bit invariably rips off though...
- X8GGY
17 Aug 2021 05:32 #237624
That's the rear one LambertIt should be a nut and bolt job the rubber part has a large metal hex built in but how much will remain after years of winter roads is debatable.
17 Aug 2021 05:57 #237627
Yes of course it is. Senior moment.
17 Aug 2021 06:02 #237628
I have just adjusted the text scale on my phone so I can actually see what I'm trying to read. Getting old sucks.
Time to create page: 0.166 seconds
