Oil pressure switch thread size
- Motleycrew
Topic Author
- Elite Member
- Thank you received: 23
14 Aug 2021 16:54 #237549
by Motleycrew
Oil pressure switch thread size was created by Motleycrew
Hi there,
Does anyone know the thread size of a gen3 Jimny oil pressure switch. I am going to re-purpose it for a bosch dual oil pressure and temp sensor but will no doubt need a adapter.
cheers
cheers
- Thank you received: 2005
14 Aug 2021 17:19 #237550
Replied by Lambert on topic Oil pressure switch thread size
Which engine, g13 or m13?
- Motleycrew
Topic Author
- Elite Member
15 Aug 2021 08:42 #237561
by Motleycrew
Replied by Motleycrew on topic Oil pressure switch thread size
Thanks for your reply, having looked into more I should put a sandwich plate on the oil filter. I have a m16a non vvt engine. Most ones I found that claim they fit a JDM size of 20x1 but when I measure the thread on the Jimny oil filter screw it seems to be 18mm?
- Motleycrew
Topic Author
- Elite Member
15 Aug 2021 08:48 #237562
by Motleycrew
FyI I will setup mechanical lines to the gauges. I didnt realise that the bosch dual sensor can not be ran to a dial directly. Its possible to send it to the link ECU I will have but would be a nightmare to output it to a dial plus the ECU would not be using the data for lookup etc.
16 Aug 2021 18:28 #237609
by fordem
Replied by fordem on topic Oil pressure switch thread size
1/8" BSPT on both G & M series engines, and every other Suzuki engine I've ever looked at.
- Roger Fairclough
- Thank you received: 225
16 Aug 2021 20:21 #237614
by Roger Fairclough
Replied by Roger Fairclough on topic Oil pressure switch thread size
What fordem said.
For a suitable adaptor, try a hydraulic hose and fitting supplier.
Roger
Roger
