Warning light?
- JimnySuffolk
08 Aug 2021 21:09 #237423
by JimnySuffolk
Warning light? was created by JimnySuffolk
Ladies//Gentlemen
Does anyone know the meaning of the lower of these two warning lights? I don’t have a manual and can’t find the answer online.
thanks very much in advance.
08 Aug 2021 21:39 #237424
by Fossie
Replied by Fossie on topic Warning light?
Engine management light
Immobiliser .
Immobiliser .
The following user(s) said Thank You: JimnySuffolk
08 Aug 2021 21:43 - 08 Aug 2021 21:45 #237426
by Scimike
Replied by Scimike on topic Warning light?
As above,
top is Malfunction Indicator. On with ignition but should go out when the engine is started.
Bottom Immobilizer. On when you switch the ignition on, but should go out when after a few seconds. Flashing or on indicate s a fault. If it's permanently on it may not be possible to start the vehicle.
Last edit: 08 Aug 2021 21:45 by Scimike.
