Fiddle brakes
- Lukeparky333
07 Aug 2021 17:54 #237371
by Lukeparky333
Fiddle brakes was created by Lukeparky333
I’ve got a reasonably standard 2003 jimny and am looking at installing a second handbrake lever and being able to operate each rear individual wheel by each lever, thinking of putting it next to the existing lever. How can I do this? Has anyone else?
- Roger Fairclough
- Thank you received: 225
07 Aug 2021 20:41 #237373
by Roger Fairclough
Replied by Roger Fairclough on topic Fiddle brakes
Just a couple of points.
Make sure you have enough room between each lever to easily get your hand to it without snagging.
I suggest you convert each lever to a "fly off" system.
Roger
Roger
- Thank you received: 2004
08 Aug 2021 03:48 #237382
Replied by Lambert on topic Fiddle brakes
If you're not using the Jimny on the road then you can probably get away with something simple like that. If you are going to be submitting it for the mot though, you'll need to invest in a somewhat more comprehensive system so that you still have a correctly functioning hand brake that operates on both rear wheels simultaneously.
- Groundworker
08 Aug 2021 07:35 #237386
by Groundworker
Replied by Groundworker on topic Fiddle brakes
I've seen triallers set up like this with one lever either side of the handbrake lever, a plate welded across the existing handbrake lever then pulls up both fiddle levers and holds them on the ratchet. Presumably original lever is disconnected from the brakes and is just employed for the ratchet.
Think you'd struggle for room in a jimny though, generally fitted in a stripped out land rover.
Interesting to see if Jimny had the power to utilise them fully, could be interesting in terms of stability if not on level ground.
- Lukeparky333
08 Aug 2021 12:14 #237395
by Lukeparky333
Replied by Lukeparky333 on topic Fiddle brakes
Yes I have tried to measure up and think it will be ok what’s a fly off system
- Lukeparky333
08 Aug 2021 12:15 #237396
by Lukeparky333
Yes was thinking of it for the technical stuff I like with wheel lifts etc, but was going to make a catch to lock them together which would surely work
Time to create page: 0.096 seconds
