2WD-L on a late -2005 VVT
- Filfrasen
07 Aug 2021 10:43 - 07 Aug 2021 11:03 #237362
by Filfrasen
2WD-L on a late -2005 VVT was created by Filfrasen
Hi.
I read in the "Jimny wiki" its possible to drive in 2WD-Low in a Jimny ho has a button operated transmission system if you modify the white cables to the solenoid for the front vacuum hub heads.
My English i bad and i dont understand if i should short circuit the white cabels to the cars ground, or just cut the white cables and put a switch on if i will have 2WD-Low ability ?
Regards
Nicklas from Sweden.
www.bigjimny.com/mediawiki/index.php/2WD-L_transmission_mode
Regards
Last edit: 07 Aug 2021 11:03 by Filfrasen.
07 Aug 2021 20:05 - 07 Aug 2021 20:05 #237372
Replied by yakuza on topic 2WD-L on a late -2005 VVT
As I understand it, put a switch between the two wires, no cutting. The switch will connect the wires. Someone Please correct me if I am wrong.
På svorsk: ansluta och koppla en brytare mellan dom två vita ledningarna så att den kortslutar för at legga ut naven i framaxeln.
Hoppas jag har rätt.
Husk vi har en norsk seksjon her inne også, men lite aktivitet der i det siste. Alle nordmenn kan svensk takket være Astrid Lindgren, Pippi og Emil.
Last edit: 07 Aug 2021 20:05 by yakuza.
The following user(s) said Thank You: Filfrasen
07 Aug 2021 21:43 #237376
by HUN
TrailMaster 2" lift kit
ORE transfer box HD brackets
T-Max split charge system
Flo-Flex castor polybushes
Kumho KL71 tyres
AVM manual hubs
ORA radius arm guards
Push-fit breathers
Replied by HUN on topic 2WD-L on a late -2005 VVT
I cannot comment on solenoids and switches but there is a much more simple solution to achieve the desired 2WD-L mode:
Discard the vacuum hubs and install manual locking hubs instead.
Kumho KL71 tyres
AVM manual hubs
Push-fit breathers
- muto
08 Aug 2021 00:51 #237381
by muto
Replied by muto on topic 2WD-L on a late -2005 VVT
Short circuit sound like a bad idea. I'm interested mod my car, but don't want to kill 4wd controller.
- Filfrasen
08 Aug 2021 07:23 #237385
by Filfrasen
Replied by Filfrasen on topic 2WD-L on a late -2005 VVT
Manual locking hubs vill work, but is not optimal on a every day car.
A switch is a easy fix whit few disadvantage if it works.
- Filfrasen
08 Aug 2021 08:04 - 08 Aug 2021 08:59 #237388
by Filfrasen
Last edit: 08 Aug 2021 08:59 by Filfrasen.
Time to create page: 0.197 seconds
