exhaust downpipe
25 Jul 2021 16:32 #236963
by mag
exhaust downpipe was created by mag
Hi
My downpipe is leaking where it goes into the cat , the weld all way round has gone , think i hit it when out last week , rattles and squeaks all the time now , can it be welded round the seam or is it just easier to replace it
25 Jul 2021 18:02 - 25 Jul 2021 18:05 #236966
by Scimike
Replied by Scimike on topic exhaust downpipe
I think it's actually a common failure point. Pipe into front of CAT fails at the weld. Yes it can be welded and you may get a few more years, but if you can't weld it yourself may be cheaper in the long term to just fit a new CAT section. They are not too expensive, circa £60 -£90 last time I looked. Mine failed in exactly the same way and even though I have the welder I didn't fancy welding on my back. As I needed to remove to weld I simply got a new one and fitted that.
Last edit: 25 Jul 2021 18:05 by Scimike.
- Thank you received: 679
25 Jul 2021 19:59 #236970
Replied by DrRobin on topic exhaust downpipe
One of the cats has just gone on my other car, so bought a BM pipe and cat from eBay, they have arrived, not fitted yet, but look really good. Anyway, I checked the price for a Jimny, the front pipe/cat goes from the manifold joint all the way to the joint for the back box, they are £54. I was tempted at that price to change the Jimny, except everything will be seized.
I am not sure if Martin sells the genuine Suzuki part in the shop, if it is not much more you might want the genuine article, if not have a look at B M Catalytic Converters, they seem to be made in the UK and I like the look of it.
Robin
Robin
- Dirtbird
23 Aug 2021 21:52 #237827
by Dirtbird
Replied by Dirtbird on topic exhaust downpipe
Buy a new one is the best long-term solution.
