Fuel injector info
5 years 5 months ago #235615
by Old Neil
Fuel injector info was created by Old Neil
I have a G13BB motor and wondering is there a higher flow rate injectors that would fit
What is the brand name of injectors Suzuki use
Thanks Neil
Thanks Neil
5 years 5 months ago #235617
Replied by Riccy on topic Fuel injector info
Injectors are denso and there are many options that fit, but its trial and error to see which will work. Without changing the ecu and throttle body its unlikely to benefit the performance though, if thats what your after.
I am using jimny 1.3 injectors in my m18 with ecu and throttle bodies. They only just top out on duty cycle when at high rpms, bringing in the second set of injectors, so I would assume the 1.3 injectors are adequate for the 1.3 engine, unless its turbo'd
The following user(s) said Thank You: Old Neil
Time to create page: 0.068 seconds
