Re:Re:Lacking power
- TS2211
16 May 2021 12:50 #235087
by TS2211
Replied by TS2211 on topic Lacking power
The weight increase without passengers is 140KG. With me and my Mrs inside the weight increase combined is 328KG. Stock vehicle weight is 1135KG.
- TS2211
16 May 2021 12:51 #235088
by TS2211
Replied by TS2211 on topic Re:Lacking power
Hi,
Yes it's had a brake upgrade.
- TS2211
16 May 2021 13:00 #235089
by TS2211
I'm not sure what the relevance of this is? What's the snorkel got to do with anything?
- TS2211
16 May 2021 13:06 #235090
by TS2211
Replied by TS2211 on topic Re:Re:Lacking power
I didn't install the winch on this or the ARB recovery bumper. I just couldn't pass on buying a vehicle with over 20K extras on an already expensive car for 30k.
I've came here to ask for advice and detailed everything the previous owner did to this Jimny with the help of the creator of this forum. I think the thread has heavily side tracked even debating insurance lol. I just want to know if there's a middle ground for better highway performance and off roading.
- Thank you received: 2004
16 May 2021 13:20 #235091
Replied by Lambert on topic Re:Re:Lacking power
Yes there is. It's going to involve accepting that a Jimny that is close to GVM is going to be quite bad on fuel and neither quick nor fast. Yes it is potentially possible to throw significantly large amounts of money at making it more powerful for example adaption to individual throttle bodies or for similar work fitting reduction gears to allow the available power to be used more constructively but neither will do much for the fuel consumption. The other alternative will involve putting the car back closer to standard and on a diet but then you loose the cooler toys and aesthetic you have paid for. There will always be a compromise as perfect doesn't exist.
16 May 2021 13:46 #235092
by RainerK
Replied by RainerK on topic Re:Re:Lacking power
Increasing the allowable load (or weight) of the Jimny is, at least in Austria, no issue. There a lots of Jimnys with snow plow and salt dispenser and this equipment requires more carrying capacity.
The only pieces that are exchanged are the springs. Supplied is also a certificate that is required to have the vehicle data changed accordingly.
www.horntools.com/suzuki-jimny-25mm-aufl...zubehoer/p-7458.html
The following user(s) said Thank You: TS2211
Time to create page: 0.106 seconds
