Lateral rod touching diff housing?!
11 May 2021 09:16 #234959
by gv42
Lateral rod touching diff housing?! was created by gv42
A puzzle! had to fit new bushes to the front arms ( chassis ) noticed the caster correction bushes were not fitted in the correct position, so sorted that, also when i had the car, it had a slightly bent down knuckle arm ( tie rod end bolts onto ) replaced that partnow the Lateral rod is now touching the diff housing and even rotates the UJ on the prop shaft when you steer! by fixing/sorting things out, i have made it worse! everything looks ok, arms not bent, no loose bolts!?
- Thank you received: 2004
11 May 2021 09:36 #234961
Replied by Lambert on topic Lateral rod touching diff housing?!
Have you put the track rod on top of the knuckle arms? It should be nuts up.
11 May 2021 09:41 #234962
by gv42
Replied by gv42 on topic Lateral rod touching diff housing?!
nuts up!
11 May 2021 11:24 #234967
Oh, ermm?
11 May 2021 15:42 #234977
by gv42
So the old slightly bent down knuckle arm is back on the car it's OK now so it' Oh ,ermm ?????
11 May 2021 17:40 #234982
How odd..does the bend seem to be manufactured or more diy?
Time to create page: 0.101 seconds
