04 gen 3 fuel issue
  • littleredjim
06 May 2021 15:57 #234896 by littleredjim
04 gen 3 fuel issue was created by littleredjim
hi everyone im recently new to owning a jimny, all was well for the first couple of days then got back from a 15 min drive parked her up and she cut out just whilst ticking over, checked alll the usual stuff and come to the conclusion that it wasnt getting any fuel! [yes it has fuel ] i checked the relay and that seems fine so ive also gone ahead and changed the fuel pump however that hasnt solved anything!! has anybody else had a problem like this or have any suggestions please help me out im dying to get out in it after owning it nearly a month and only using it twice lol ! thanks in advance
06 May 2021 16:02 #234897 by Lambert
Replied by Lambert on topic 04 gen 3 fuel issue
When you say checked the usual stuff what are you including? Have you checked the cam/crank sensor?
  • littleredjim
06 May 2021 16:06 #234898 by littleredjim
Replied by littleredjim on topic 04 gen 3 fuel issue
thats only thing i havent however i did forget to mention i ran a temporary inline pump just to see if it would start and it did but would only tick over as it was a weak pump
06 May 2021 16:58 #234900 by DrRobin
Replied by DrRobin on topic 04 gen 3 fuel issue
Fuel filter?
  • littleredjim
06 May 2021 17:01 #234902 by littleredjim
its had a whole new fuel unit in mate so that shouldnt be an issue
06 May 2021 20:27 #234904 by Scimike
Replied by Scimike on topic 04 gen 3 fuel issue
If it's is lack of fuel - I would guess the fuel relay is not seeing engine pulses and shutting down, so it's the pulse generation route (not sure how this is achieved on a Jimny) or the relay. Have you tried hard wiring the fuel pump as a test?
Just throwing in some ideas without the benefit of a circuit diagram.
Time to create page: 0.106 seconds
