Battery upgrade
- Phattaff
04 May 2021 19:55 #234849
by Phattaff
Battery upgrade was created by Phattaff
Hi all
Can I just swap the batteries over or do I need to do something to save the vehicle codes?
Cheers in advance
Cheers in advance
04 May 2021 21:00 - 04 May 2021 21:01 #234853
by Scimike
Replied by Scimike on topic Battery upgrade
Hi,
I've disconnected the battery on my 2009 GEN3 many times without issue. I have a replacement stereo head unit that has no code, can't recall if the OEM Clarion was code protected, so watch out for this just in case. Key codes and central locking also not had any issue. ECU fault codes (did you mean these?) could clear if the battery is disconnected for some time, but if it's a real fault it will soon be back.
Not sure if things are different for the GEN4.
What do you have?
Mike
What do you have?
Mike
Last edit: 04 May 2021 21:01 by Scimike.
- Phattaff
05 May 2021 15:53 #234880
by Phattaff
Replied by Phattaff on topic Battery upgrade
Cheers for the info, gen 3 so will now be looking for a suitable upgrade.
Time to create page: 0.171 seconds
