Re:Kingpin Bearings - Advice
- Thank you received: 115
The Steering Damper isn't needed when:
1) King Pins are fixed
2) Bearings are fixed
3) Panhard Buhes are fixed
4) Tie Rod Ends are fixed
5) Clean and Balanced Wheels
Jalapeño, IISY?
I'm not sure a damper will achieve what you're looking for. A deathly tight grip on the wheel is a sure way to feel unsettled in a Jimny. There is a natural amount of vagueness in the chassis (tall tyres, soft suspension, soft bushes, steering box rather than a rack...) that means a small amount of wandering is innevitable and steering response will never be as immediate as a regular car. On faster roads I tend to drive with the wheel between finger and thumb and "guide" the car in the right direction rather than fighting it with constant inputs and corrections. I can drive quite comfortably at 80mph with little more fatigue than any other car.DrRobin wrote: I found that on a run to see my parents (200 mile round trip), I would be gripping the steering wheel quite tightly and you can feel it in your arms when you get back home, if the damper eases that, it will be well worth it.
I am going to go for an Armstrong type damper, I think on balance I would like the steering a little less sensitive, especially at around 60mph.
- Thank you received: 520
Re the damper, I am going to fix the problem first, I hate anything that is wrong and always want to get to the bottom of the problem, if you don't it comes back to bite you.
It's the same for all of my vehicles any unusual noise or rattle gets investigated and also in my work (electronic design/manufacture).
The damper is not going to be there to hide the problem, it is just that personally I think the steering is a little on the light side.
Robin
- Thank you received: 1837
Going to the garage I took a wrong road and had to do a U-turn, it was almost impossible to get full lock at slow speed. That demonstrates that PAS is required on even a small car and at slow speed on un-even ground I don't think you could live without it.
However, at 50mph+ I just think it is a little light so will try the damper, I am not expecting it to be as rock solid as my Boxster, just somewhere in between will suit.
Speed (electronic) adaptive steering would be the best of all worlds, but it would push up the price,
Robin
Jalapeño, IISY?
