Re:Co2 in coolant but no overheating
17 Mar 2021 23:18 #233832 by adwarc
fordem wrote:
adwarc wrote: A friend of mine has a block from a g16 engine.
Could it be posible to fit the g16 block only with everything else from the g13?
Does g16 block only mean the bare block, and everything else from the g13 include the crankshaft, pistons & rods?  Then the answer is no.  Both the bore & the stroke are different, it might be possible to swap a G16 short block in and fit the head etc. from the G13, as the same head casting is shared by both engines, but, the G16 short block would have to be a 16 valve, and you'd need adapter plates to mate it to the transmission, so not a drop-in, bolt up swap.
Sorry i wasn't clear. Its a g16 16valve full block.
So i guess it will fit?
But i haven't a sump.
Anything else except the adapter? The starter motor?
Στάλθηκε από το SNE-LX1 μου χρησιμοποιώντας Tapatalk
18 Mar 2021 17:05 #233840 by fordem
Google G16 G13 swap, you're going to get a lot of hits, if you include Jimny as a keyword in the search string you'll get results more in tune with what you're attempting - the exact details are going to vary with what vehicle the G16 came out of.
Time to create page: 0.411 seconds
