Re:Co2 in coolant but no overheating
15 Mar 2021 10:27 - 15 Mar 2021 10:51 #233739 by adwarc
Greetings from Greece guys.
Just bought a Jimny with a G13 engine.
The car had been sitting for a year or so.
Yesterday i run a test with the radiator and found Co2 in the coolant.
But the car isn't overheating.
The mechanic said its a blown head gasket or a cracked head.
I haven't done any service to it since i went to the shop to do it but we found this.
Could it be anything else?
I've red a post here that it wasn't a gasket but a loose rad hose.
Sorry for my bad English :)
Στάλθηκε από το SNE-LX1 μου χρησιμοποιώντας Tapatalk
Last edit: 15 Mar 2021 10:51 by adwarc.
15 Mar 2021 10:32 #233740 by Lambert
Welcome to the forum. I would tend to agree with the mechanics assessment. When my head gasket failed I did get much in the way of alarming overheating but it would get warmer and warmer and not cool properly.
15 Mar 2021 10:43 #233741 by adwarc
Thanks for the reply my friend.
That's the problem. Mine isn't overheating at all...
15 Mar 2021 12:49 #233743 by Lambert
You can buy cheap DIY kits off amazon eBay etc if you're wanting to confirm the diagnosis.
17 Mar 2021 21:45 - 17 Mar 2021 21:46 #233829 by adwarc
So today we open up the engine and the gasket is gone.
We will send the header for repair and also the engine block.
Another question. :)
A friend of mine has a block from a g16 engine.
Could it be posible to fit the g16 block only with everything else from the g13?
Last edit: 17 Mar 2021 21:46 by adwarc.
17 Mar 2021 23:04 #233831 by fordem
adwarc wrote: A friend of mine has a block from a g16 engine.
Does g16 block only mean the bare block, and everything else from the g13 include the crankshaft, pistons & rods?  Then the answer is no.  Both the bore & the stroke are different, it might be possible to swap a G16 short block in and fit the head etc. from the G13, as the same head casting is shared by both engines, but, the G16 short block would have to be a 16 valve, and you'd need adapter plates to mate it to the transmission, so not a drop-in, bolt up swap.
Time to create page: 0.263 seconds
