E10 petrol and gen 3 Jimny
11 Mar 2021 21:05 #233662
by Mabster
E10 petrol and gen 3 Jimny was created by Mabster
Hello I have a 2001 gen 3 and wondering if E10 petrol is likely to damage any rubber / plastic components anywhere in the fuel system? I understand that owners of older cars / other makes such as VWs have fuel leaks where the ethanol is 'drying out' rubber components, causing cracking. Does anyone have a view or am I wrong to be concerned? Thank you.
11 Mar 2021 21:15 #233663
Replied by mlines on topic E10 petrol and gen 3 Jimny
Suzuki tech say it will be fine
The following user(s) said Thank You: Mabster
11 Mar 2021 21:23 #233664
by Mabster
Replied by Mabster on topic E10 petrol and gen 3 Jimny
Thanks Martin!
- Axholme Lion
26 Mar 2021 10:24 #234039
by Axholme Lion
Replied by Axholme Lion on topic E10 petrol and gen 3 Jimny
Can you not buy additives to counter act the effects of the ethanol?
I won't be putting any E10 anywhere near my cars. I always use Shell V Power which i believe will remain E5.
- Roger Fairclough
- Thank you received: 225
26 Mar 2021 12:27 #234040
by Roger Fairclough
Replied by Roger Fairclough on topic E10 petrol and gen 3 Jimny
If Suzuki Tech. says it will be OK, what's the problem?
Roger
Roger
02 Apr 2021 11:05 #234193
by facade
You don't want ethanol mix hanging around in your fuel tank, it rusts steel, and holds water.
The ethanol free costs a bit more, but you will get higher MPG which will compensate a bit. (ethanol has a lower calorific value than petrol, so it is another stealth tax- you have to buy more fuel, and therefore pay more duty and VAT)
Replied by facade on topic E10 petrol and gen 3 Jimny
The Esso equivalent is ethanol free, I use it in my 'bike, and I have been putting it in the Jinmny recently, as it has only done about 200 miles since last March. I've seen what 10% ethanol does to plastic fuel filter casings in the USA- they go bright yellow and swell up.Axholme Lion wrote: Can you not buy additives to counter act the effects of the ethanol?
Time to create page: 0.996 seconds
