Re:New head gasket install help
05 Mar 2021 16:29 #233465 by LM42
Hello!
 Need to replace my head gasket on my 2003 Jimny,  so apart from the complete head gasket set, and the Themostat , what is worth changing?
05 Mar 2021 23:21 #233472 by Scimike
Hi,
Sorry but I don't know, luckily for me it's a job I have not needed to do on our Jimny, so I will be reading with interest.
In the good old days (yes I am old-ish) it was good practice to get alloy heads skimmed or at least checked for flat by a machine shop before you put a new gasket in. Those that have changed gaskets on here never mention this, so is it something not worth doing on the Jimny?
If nothing else I've bumped your question back to the top ready for those with a better insight into this engine.
Good luck with your endeavour.
Mike
05 Mar 2021 23:57 #233473 by Old Neil
LM42 wrote: Hello!
What is the symptoms of needing new head gasket i was working on car had bubbles in coolant it was sucking air from poor sealing rad hose near water pump + recently had new water pump fail
More info please
06 Mar 2021 05:42 #233475 by Lambert
When I had mine done at the garage I think it got a light skimming but I didn't do the job. Other than that I had by process of elimination replaced all the ancillary components related to cooling anyway. However I did end up needing a new front crankshaft oil seal as they tried to reuse the existing which it didn't like and because they took the motor out to do the clutch at the same time they also disturbed the heater matrix which started leaking and coincidence or not the starter motor also didn't like being interfered with. So with some warranty work and some additional work by me after the fact my head gasket and clutch change came in at about 1800 quid. The only saving grace was that when they were inside the motor they reported it was like new which is good at a hundred thousand miles.
06 Mar 2021 23:50 #233496 by LM42
looking at crank shaft seal!, its pushing coolant into the expansion bottle, also it seems to discolor it, also white smoke/ steam on start up
compression test seems to show a drop in psi on the middle 2
07 Mar 2021 01:15 #233498 by Old Neil
LM42 wrote: looking at crank shaft seal!, its pushing coolant into the expansion bottle, also it seems to discolor it, also white smoke/ steam on start up
sounds like more than a simple head gasket it's ether corroded or warped you won't know till you remove the head like other people on this forum have said the minimum you have to do is have the head skimmed but you have to check the whole cooling system if there is a folt you will cook the new head
It's not a simple job can be done at home apart from the welding and machining
need good tool kit inch lb and foot lb torque wrench + work shop manual
