frot hub leaking
01 Mar 2021 14:08 #233371
by safari
if u worry u die if u dont worry u still die so why worry
frot hub leaking was created by safari
Hello i have just refurbished my front hubs so seals and bearings all new but just after 1 month i found them all soaked with greece and i think also oil casue the colour is greyish . i have done them many times and this never happened to me before.Only thing i did not change is the dust cover placed on the back of the hub and are a bit old . can water get in there from them ?. What can be the problem ?
- Thank you received: 2004
01 Mar 2021 16:49 #233374
Replied by Lambert on topic frot hub leaking
Did you get the seals from a known good supplier?
01 Mar 2021 17:01 #233375
by safari
Replied by safari on topic frot hub leaking
yes i always buy from him and have always been good but can water get in and so greece get out from the dust cover of the hubs pls
01 Mar 2021 17:16 #233376
by Busta
Replied by Busta on topic frot hub leaking
The dust cover is exactly that. It doesn't stop water getting in or oil getting out. But there shouldn't be any grease in the swivel to leak out. The only bits that should be greased are inside the CV joint and the kingpin bearings. If you have put grease anywhere else (e.g. filled the whole joint with grease as you would on a landrover) then this will inevitably leak out past the dust seal. I have never found a need to change the dust seal on a Jimny swivel.
Otherwise check the condition of the sealing surface on the driveshaft.
02 Mar 2021 12:48 #233395
by safari
i have to take everything off again cause very confused what could have happened and went wrong
- rayz_x
17 Apr 2021 18:15 #234530
by rayz_x
Replied by rayz_x on topic Re:frot hub leaking
Have you done this yet? I just had the same. When I took it apart the seal had come out and was hanging on the shaft. Replaced with a new seal and it's leaking again. Taking it apart tomorrow. Maybe the seal needed tapping in further. Hopefully won't be a big problem.
Sent from my moto g(7) power using Tapatalk
Time to create page: 0.108 seconds
