IAC valve info
06 Feb 2021 11:16 #232526
by Old Neil
IAC valve info was created by Old Neil
Sorry me again
on the G13BB, the idle air control valve has anyone had to replace one, what symptoms do they give when they are failing how to test it (it still makes rotating sound when first switched on)
on eBay Goss and Tridon each list there version but on there website i can't a listing?
Thanks Neil
Thanks Neil
- Thank you received: 2006
06 Feb 2021 12:48 #232530
Replied by Lambert on topic IAC valve info
I don't know enough about the g13 but what is making you suspect it has a problem?
06 Feb 2021 13:06 #232532
by Old Neil
Replied by Old Neil on topic Re:IAC valve info
process of elimination i still have a throttle fluctuation at a set speed after cleaning IAC with throttle body cleaner it's not as bad if i find one for sale they are over $300(Australian)just wondering if someone knows a way test it + G13BB is OBD one so can't use readerLambert wrote: I don't know enough about the g13 but what is making you suspect it has a problem?
Time to create page: 0.147 seconds
