Diff lockers
18 Jan 2021 13:33 #231922 by maverick
Replied by maverick on topic Diff lockers
I have a pair (front and rear) of Kaisers from www.jimnybits.com/suzuki-jimny-automatic...ocker-by-kaiser.html
Jalapeño, IISY?
18 Jan 2021 16:53 #231931 by Riccy
Replied by Riccy on topic Diff lockers
Ive ARB front and rear and they are great, but like Sniper says, very much on or off. An extra level of complexity having the compressor and air feeds/seals, not one I think I would choose again cause when it goes wrong its back to open diff time (had a seal blow out at a pay-n-play day and no rear locker for the rest of the day, also in turn the seal let the axle case fill with compressed air, which then found its way through the breather system to the gearbox and blew out a bung in that).
I like the sound of the elec one Sniper mentions best, in that it works as a limited slip generally, then can be locked fully if desired. Open diff at the back doesnt really work well for me if im trying to put down the full 130hp on the road and hilarious on a slick surface.
18 Jan 2021 21:49 #231938 by Busta
Replied by Busta on topic Diff lockers
I prefer to go by the name Busta :)
18 Jan 2021 21:50 #231939 by Busta
Roger Fairclough wrote: I fitted an Eaton Tru-Trac unit to the rear axle of a Land-Cruiser 70 series....
Unfortunately Eaton don't make a Tru-Trac for the Jimny.
19 Jan 2021 07:35 #231940 by sniper
Replied by sniper on topic Diff lockers
A little confusion Riccy.....
As Busta has mentioned the Quaife ATB has a negative in that you lose drive across the axle if one wheel is lifted. In real world terms, it's not really a big issue, since fitting an ATB (3 years ago) i have never failed a climb or gotten stuck in a cross axle situation.
Quaife have addressed the issue with their new "Wavetrac" differential, it is basically an ATB with constant drive, even with a wheel lifted. Not produced for the jimny as yet..... We can only hope....
I drive on loose ground regularly (at least weekly) but the car still spends 95% of it's time on tarmac. On the road, all of the other types of "locker"  give no benefit at all and the cheaper "Lockrite" type units can be a hinderance..... Whereas the Quaife ATB alters the chassis dynamic in a big way if you are an enthusiastic driver. So long as you have tyre grip, more power tigtens your line in a corner and makes the little Jimny behave like an old RWD Escort.....
My Jimny is pretty well set up and can outdrive many saloon cars on tight and twisty B roads, certainly any other 4x4. Drifting is easy to instigate and control, lots of fun....
Dave Marsh Racing have modified an ATB to fit the front diff and as soon as the Wavetrac is available to fit in the rear axle on my car, i will be asking them to do the same on mine and fitting a Wavetrac in the rear axle.....
The Quaife unit is fit and forget, no maintenance and nothing to fail or wear. So long as it has oil, forget about it....
sniper
The following user(s) said Thank You: lookonimages
19 Jan 2021 09:06 #231942 by lookonimages
Replied by lookonimages on topic Re:Diff lockers
sniper wrote: A little confusion Riccy.....
sniper
Thank you for sharing some insights. Keep us posted please as I might be tempted into the wavetrac. Will go google now.
Time to create page: 0.119 seconds
