engine light help please
- a18suf
28 Nov 2010 19:56 #6726
by a18suf
engine light help please was created by a18suf
hiya my engine warning light came on a week ago and a couple of people said disconect the battery for a couple of minutes and it went off.
but now it has come on again after 24hours! does anyone know common faults that could cause this?
thankyou
thankyou
28 Nov 2010 20:13 #6727
Replied by mlines on topic Re: engine light help please
The engine light has some computer logic behind it. If a fault has not re-occured on two starts, it clears itself. The fact that it is still on means the fault is still there. Disconnecting the battery only fools the logic for a couple of starts and then the light comes back on.
I don't know what year your Jimny is?
If its an early one then there is a connector under the dash that you can put a loop of wire in, this will cause the engine light to flash a code at you which will tell you the problem.
Later models require a code reader, but some code readers do not work with some Jimnys as there is a transition period during which the code reader connection has the later style of connector but the earlier style of code (OBD1) - these are very difficult to get the code out of.
I think you are going to Tong, if so we can read the code for you if its the loop version or you can use my code reader if its an OBD2 later version.
- a18suf
28 Nov 2010 21:05 #6728
by a18suf
Replied by a18suf on topic Re: engine light help please
hiya. Its a 2004. It is driving ok and does not seem to have a major fault but i know that light will come on for lots of reasons. I wasnt sure if there was a couple of common problems that people know of. Thank you
28 Nov 2010 21:15 #6729
Well there are around 40 codes listed, but a 2004 one should be readable with a standard code reader, I will have mine with me at Tong
The following user(s) said Thank You: a18suf
- pjlee25
24 Dec 2010 14:07 #8062
by pjlee25
Replied by pjlee25 on topic Re: engine light help please
Hi,
I have this problem ... and have done through many checks. Diagnosis ranges from catalytic converter problem, to O2 sensor problem, to other sensor problem. Did a change in the sensors but the problem still persist. The light will come on whenever I maintain a cruise speed of 70-80km/h for about 20-30 mins.
End state: decided to get a OBDII scanner and reset the engine light whenever it comes on.
- bertbuckie
24 Dec 2010 19:41 #8079
by bertbuckie
If the lights coming on, and you have changed sensors etc then theres a fault.... ignoring this could be costly if the jimny's anything like any other car I have had.....bad idea to reset without knowing what your doing
Replied by bertbuckie on topic Re: engine light help please
pjlee25 wrote: End state: decided to get a OBDII scanner and reset the engine light whenever it comes on.
Time to create page: 0.172 seconds
