4wd problems
- Roger Fairclough
- Thank you received: 225
31 Dec 2020 13:50 #231372
by Roger Fairclough
Replied by Roger Fairclough on topic Re:4wd problems
I am glad you agreed with the maths, that at least proves that driving in a straight line can be damaging. Also, as I pointed out, driving a curve is also detrimental as that just increases the problem.
My comment relating to Land-Rovers did not include post 80's models as the previous series 1-3 did not have center diffs. at least in production.
There are many reasons why a half shaft can snap, twisting being the most obvious but the ones I have seen exhibit this phenomenon over a period of time due, probably, to poor material of inadequate strength and design and probably wind up caused by the driver not realising how much damage will be caused. From my own experience of RTV trials, many Land -Rover drivers regularly abused their mounts and replied to criticism "oh it will be ok" and when something broke they came up with every excuse other than driver error.
Now I have made my point and will leave the other members to make their own decisions.
Roger
Roger
- Roseblade
31 Dec 2020 15:44 #231374
by Roseblade
Replied by Roseblade on topic Re:4wd problems
Glad that argument is done with.
I don't want to start another but it seems to me that the old style 4 wd as in Jimnys, old landies etc with part time 2wd and no centre diff all have a major flaw. If you are driving on mixed surfaces, that is soft one minute then hard the next you run the risk of wind up or you have to keep shifting out of 4wd. That system is also fairly useless for driving on icy roads where you don't know the ice is there until you are dancing on it. I guess that's why landrover went to permanent 4 x 4 with centre diff. That system however also has a major flaw which is why they include a diff lock thereby putting you back in to much the same situation as before.
I would love to see a jimny with permanent 4wd and a centre diff (ala defender) but with all 3 diffs being limited slip. I reckon they would be unbeatable.
I would prefer that to all the electronic gizmos that pack up as soon as you sniff at them (ala modern landies like rangees and disco's electronic shift jimny's etc).
There you go folks, I have lit the touch paper.
Ps This is not about jimny over landies, I have owned a series 3 landie and a defender and SJ413 and currently Jimny.
They all have their qualities and faults/limitations. All engineering designs are a form of compromise. You pays your money and make your choice.
31 Dec 2020 17:34 #231376
by Busta
Replied by Busta on topic Re:4wd problems
A viscous coupling, as used in Freelanders and many other AWD systems, achieves a similar result to an LSD in the centre diff would. There has been some discussion on here about running one in the front prop on a Jimny. This would allow you to run in 4wd all the time.
- Roseblade
31 Dec 2020 17:51 #231377
by Roseblade
Sounds possible in theory, However I have heard complaints about freelander and other vehicles that use similar systems that there are problems with them.
One being that they have a tendancy to lock up, and another is low spread and cornering drag. I wonder if it would be too detrimental to the fuel consumption on a small engine vehicle like a jimny (already known to be a tad thirsty).
I suspect the extra weight and drag from the set up I suggested might also cause the fuel consumption to go beyond reasonable. So maybe some brave soul needs to experiment. Anyway I was thinking really about offroaders more than normal use on road. It would be interesting to see both set ups side by side.
- Thank you received: 2005
31 Dec 2020 18:40 #231379
Replied by Lambert on topic Re:4wd problems
Most of the issues you raise about unpredictable conditions are relatively easy to overcome as it's possible to change between 4x4 and 4x2 in high range at up to 60mph so if you know it's likely that you will encounter odd conditions like it's forecast for snow or you are going up the woods it's entirely safe to run with the hubs engaged and then select 4x4 as needed on the fly. Adding a decent tyres and you are going places.
31 Dec 2020 21:55 - 31 Dec 2020 21:57 #231383
by Scimike
Replied by Scimike on topic Re:4wd problems
As Lambert said, in my experience the lack of a viscous couplng and permanent 4WD is no big issue. In fact for me it's a bonus, even less to go wrong. The Jimny has the edge over my Series Land Rover due to its ability to engage 4WD on the move, button on 4WD, button off, easy.
I tend to drive everywhere and on any surface in 2WD, only engaging 4WD if I get stuck or feel control is diminished (snow / ice), then back to 2WD as soon as possible.
As a consequence I have never experienced any issues as I spend the majority of time in 2WD, even off road.
Edit - I did accidentally leave my Series Land Rover in 4WD and went for a drive. Instantly knew something was wrong, steering felt strange. 2 miles later whilst still trying to figure out what was wrong, the Land rover literally jumped into the air with a sonic bang. At this point the penny dropped, luckily no damage.
Last edit: 31 Dec 2020 21:57 by Scimike.
