JB74 OBD2 connection
- Thank you received: 667
24 Feb 2021 09:48 #233199
Replied by DrRobin on topic Re:JB74 OBD2 connection
Battery voltage (I think the only measurement is ECU voltage) is from memory a separate gauge, not listed under the main PIDs, just click to add a new gauge, then scroll down the list, it is on the main menu somewhere, I think.
I have voltage on my Gen 3 and other car, I don't think you need a specific PID. If you can't find it I will have to have a look on my car.
- PNP
24 Feb 2021 09:59 #233200
by PNP
Replied by PNP on topic Re:JB74 OBD2 connection
thank you DrRobin, will check it out
- stuart
25 Feb 2021 13:44 #233257
by stuart
Replied by stuart on topic Re:JB74 OBD2 connection
PNP, could you let us know which terminals on your OBD socket are wired?PNP wrote: TorquePro with a Veepeak b/tooth connected fine on JB74W, looking for a battery voltage meter PID as it is not indicating?
- PNP
25 Feb 2021 14:15 #233259
by PNP
4,5,6, 14,15,16
- BlueMethJimny
11 Jan 2022 13:50 #241065
by BlueMethJimny
I purchased and tried both of the devices that worked for you, but unfortunately neither worked for me. The more expensive one only seem to have 'worked' because it has a GPS mode. But it isn't really using the OBDII connection.
I also tried my luck with the Autool X60 hoping it will be like the guy in Italy in the video, but like OP it didn't work for me too. This has become very frustrating. Why Suzuki made this so difficult for their customers is beyond me.
Replied by BlueMethJimny on topic JB74 OBD2 connection
Sorry no idea about the Torque Pro, I dont have a reader.stuart wrote: Excellent work Twisticles!! I'll be ordering one of those.
I wonder if the Torque Pro app is not compatible with ISO 15765-4 either?
https://imgur.com/KSd7E7f
Also, I bought one of these too , which is just a digital display reflected up to the windscreen. I didnt use the included plastic that you're supposed to stick where it reflects, so I get a bit of ghosting where it reflects on both the inside and outside surfaces of the windscreen. But I can live with that to have the speed so clearly in my peripheral vision.
Great little gadget for $12!
- BlueMethJimny
11 Jan 2022 13:55 #241067
by BlueMethJimny
Did you have any luck with any HUD that works with JB74W? I'm based in the Philippines and I suspect we have the same 'issue'.
Time to create page: 0.230 seconds
