4wd not working
- Lukeparky333
6 years 1 day ago #230123
by Lukeparky333
4wd not working was created by Lukeparky333
Hi guys, unfortunately I have lost drive to the front wheels when in 4H and 4L but can be selected fine but just no drive to the fronts. Can anyone help me out with possible reasons and solutions and how to diagnose.. I’m a beginner with this and don’t know where to start.. would like to have the the vacuum system over manual hubs.. thank you
6 years 1 day ago - 6 years 1 day ago #230125
by Scimike
Replied by Scimike on topic 4wd not working
Hi
Are your dashboard indicator lights working as expected?
Do you hear the hubs engage, it's a definitive "click" as the vacuum activates them, same when they disengage?
With both front wheels lifted and the vehicle in 4H or L what happens if you turn each front wheel by hand, does the other side rotate.
Don't know if you have seen the wiki, it has some good articles which may help.
www.bigjimny.com/mediawiki/index.php?tit...checking_and_testing
Last edit: 6 years 1 day ago by Scimike.
The following user(s) said Thank You: Lukeparky333
- Lukeparky333
6 years 20 hours ago #230138
by Lukeparky333
Replied by Lukeparky333 on topic 4wd not working
That’s perfect thank you so much, that’s given me a good insight into what to look for and so on I’ll give it a try and perhaps get someone to select it for me so I can listen outside and I’ll have to get it in the air sometime thanks man
Time to create page: 0.074 seconds
