Changing diff oil
  • Reason2doubt
10 Sep 2020 09:09 #228022 by Reason2doubt
Changing diff oil was created by Reason2doubt
I’m thinking about changing my diff plugs and oil as part of a larger home service. I have new plugs bought from Martin on BigJimny (about a year ago).
Is there any technique to getting the plugs out? It seemed like they were stuck solid when I last tried. Any recommendation on how to best loosen them up?
10 Sep 2020 09:18 #228023 by jackonlyjack
Replied by jackonlyjack on topic Changing diff oil
I take it you have the 10mm square socket ?
Filler plug can be removed with good set of mole grips or stilsons wrench
You could use heat but you may have a nylon washer on it
Drain plug use heat or weld a nut to it
I use a 500mm long ratchet
  • Reason2doubt
10 Sep 2020 09:23 #228026 by Reason2doubt
Replied by Reason2doubt on topic Changing diff oil
I believe so.. I have a little set of assorted ‘diff keys’ and one of them seemed to fit OK.
I will get some mole grips but I do have a welder (assuming that is the last resort!). I’ll see how I get on.
10 Sep 2020 09:27 #228027 by Scimike
Replied by Scimike on topic Changing diff oil
I don't recall the job requiring any special tools.
Remove the filler plug first, then the drain plug. Simply if you remove the drain first and can't get the filler out you are stuck.
I used a little heat on the diff housing, just got it warm, they then came out easily.
Can't recall a nylon washer, but I use blue hylomar as a thread sealant on these jobs, always works for me.
Mike
10 Sep 2020 09:34 #228029 by jackonlyjack
Yes welding a nut on is last resort
Nylon washer some do some don't,my rear has one but front doesn't
Like Scimike say's small amount of sealant i use an rtv type
10 Sep 2020 09:48 #228030 by mlines
Replied by mlines on topic Changing diff oil
The proper washer is copper
