Clear Front Indicators
- Jimny-Phil
04 Sep 2020 12:46 #227712
by Jimny-Phil
Clear Front Indicators was created by Jimny-Phil
Hi all... back with more question again!
First a big thank you to everyone that has been so helpful in the past... it’s most appreciated
I’m now looking to replace the front indicators with clear ones, to match in with the clear side repeaters that I’ve already replaced on my Gen 4
I’ve looked around at these and there appear to be more than one type / manufacturer
Some say “plug and play”, but then I’ve seen comments about them needing splicing into wiring and comments about them also being able to be wired to work as DRLs, as well as indicators... so I’m a little confused... also why do they need to work as DRLs, when there are already DRLs on the Jimny?
Does anyone have a link to some decent quality ones that are straightforward to fit (ie they actually are “plug and play”) and I can just remove the existing ones and plug the new ones in?.... or am I looking for something that isn’t available / doesn’t exist?
So, any useful comments and links would be most appreciated
Thanks
PJ
Thanks
PJ
- lookonimages
- Thank you received: 72
04 Sep 2020 13:00 - 04 Sep 2020 13:04 #227714
by lookonimages
Replied by lookonimages on topic Re:Clear Front Indicators
Not all countries got DRL as standard. Only countries where is is legal requirement got DRL as standard accessory
Last edit: 04 Sep 2020 13:04 by lookonimages.
- CC Baxter
04 Sep 2020 13:40 #227716
by CC Baxter
Replied by CC Baxter on topic Clear Front Indicators
I'm pretty sure Andy2640 fitted these, you could pm him. They've got nothing to do with DRLs though. DRL/Fog combination is on the lower grille, indicators are up high. Chris
- Roger Fairclough
- Thank you received: 225
04 Sep 2020 13:45 - 04 Sep 2020 13:46 #227718
by Roger Fairclough
Replied by Roger Fairclough on topic Clear Front Indicators
The ones that Andy fitted have clear lenses but use coloured bulbs (or something like it) but I believe Andy had a problem with water getting in (or was that the side repeaters)!
Roger
Roger
Last edit: 04 Sep 2020 13:46 by Roger Fairclough.
- Bill Portland
- Thank you received: 77
04 Sep 2020 17:02 #227727
by Bill Portland
Replied by Bill Portland on topic Re:Clear Front Indicators
Those clear indicators have drls in too. The drl switches off in the side that the indicator is flashing.CC Baxter wrote: I'm pretty sure Andy2640 fitted these, you could pm him. They've got nothing to do with DRLs though. DRL/Fog combination is on the lower grille, indicators are up high. Chris
The following user(s) said Thank You: CC Baxter
- CC Baxter
04 Sep 2020 19:01 #227732
by CC Baxter
Replied by CC Baxter on topic Re:Clear Front Indicators
Thanks Bill, I stand corrected. Chris
Time to create page: 0.166 seconds
