charging light + water
- gman
6 years 3 months ago #226756
by gman
charging light + water was created by gman
Hello,
I have a 2004 Jimny with the M13A motor 4WD.
Just recently I had the battery light being on.. i swapped out the battery (the older one was trash)..
So, i have NOT checked the alternator, will be doing that tomorrow, however, I dont think that the alternator is faulty, because when I drive in water, even just medium size puddles, the battery light goes out and it charges around 14.5 V.. I know water conducts electricity, but just wanted to ask around and see if any of you have had similar problems?
Any suggestions on where to start?
I always plug it in during the night so there is no rush.. ( It's the only Plug-in Jimny in the world :laugh: )
I have a video of me driving through a small puddle if anyone is interested, just drop your email below.
- Thank you received: 2005
6 years 3 months ago #226764
Replied by Lambert on topic charging light + water
Welcome to the forum. Err it only works properly when driving in even small bodies of water, that's new. I would be looking at earth points first and then the state of the wiring and connectors to the alternator though it could also be the alternator regulator too.
6 years 3 months ago #226789
by Scimike
Replied by Scimike on topic charging light + water
When you have checked everything above and are out of ideas:-
Water on the brush gear can help them, so it's possible your alternator brushes are on the way out.
It's a strange one as Lambert said, so my comments are a long shot.
Not entirely insane as I did "run in" model aircraft brushed motors under water as it suppress arching on the slip rings.
Time to create page: 0.077 seconds
