Failed MOT :(
14 Aug 2020 08:57 #226656 by Scimike
Replied by Scimike on topic Failed MOT :(
Hi
Can't tell much from last year's results, everything looks ok.
Pre cat sensor under bonnet on manifold, post cat sensor is after the last cat in the exhaust, under the vehicle.
Lambert s Italian tune may well just sort this, or the same with the cleaner additive, but a thrashing anyway.
If you fit a new Lambda Denso are a very good make, cost more but you fit it once.
Mike
  • setchfield
14 Aug 2020 09:39 #226659 by setchfield
Replied by setchfield on topic Failed MOT :(
Scimike and other Jimny lovers.
Thanks for the help so far.
I have just been under the Jimny. I see the little cat but no where on the pipes after it is any fitting for or any cables to a lambda sensor (post cat)
There is one on the manifold but thats it.
I am now bemused..
14 Aug 2020 12:11 #226660 by Roger Fairclough
Replied by Roger Fairclough on topic Failed MOT :(
Prior to a test take the motor for a run to thoroughly warm the engine and clear the system. As lambert said," give it a bit of a ragging". The tester should do the emissions test first. Do not let him idle the engine for minutes on end as this will choke it up, especially on a well used example.
Roger
  • setchfield
14 Aug 2020 12:43 #226662 by setchfield
thanks all
ordered denso lambda sensor.. first job.. then we will see if it is the cat.. as for the welding... I am gob smacked. all it was after removing the rear wheelarch and sill trim from the offside was a hole in the outer wheel arch extension .. the sill and its ends are solid.. I have just cut the flap of rusty metal off! He said it was structural.. balls.. I have restored many classics and no way was it structural..
grrr.
14 Aug 2020 14:07 #226664 by Roger Fairclough
I used to have an MoT inspectors ticket and modern day monocoque shells are treated in a different way to chassis's, where the chassis is considered the main structural member. Either way a fail only related to the proximity of a seat belt mounting. In my day this was 12".
Roger
Time to create page: 0.083 seconds
