Winch battery cables
- Phattaff
30 Jul 2020 17:41 #225867
by Phattaff
Winch battery cables was created by Phattaff
Ok Guys & Girls, what thickness cable do I need to run from the battery to winch???
Cheers.
Cheers.
- Thank you received: 2004
30 Jul 2020 17:51 #225869
Replied by Lambert on topic Winch battery cables
Don't know for certain but I suspect that the manufacturer will have something on their Internet
- Roger Fairclough
- Thank you received: 225
30 Jul 2020 20:40 #225874
by Roger Fairclough
Replied by Roger Fairclough on topic Winch battery cables
Depends on the amperage draw of the motor and the cable length.
Roger
Roger
01 Aug 2020 16:13 #225946
by RainerK
Replied by RainerK on topic Winch battery cables
35m2 minimum. The bigger the better so 50mm2 or even 70mm2? I would recommend a fuse directly at the battery.
- Phattaff
01 Aug 2020 16:28 #225947
by Phattaff
Replied by Phattaff on topic Winch battery cables
Cheers everyone
- GeorgeC
01 Aug 2020 19:47 #225955
by GeorgeC
Replied by GeorgeC on topic Winch battery cables
If you have difficulty finding bulk cable of suitable size, sometimes a "cheap" set of Jumper Leads will do the job, just swap the alligator clips for the appropriate sized terminals.
