Ignition coil help
19 Jul 2020 04:33 #225304 by Old Neil
Ignition coil help was created by Old Neil
Is it possible to connect individual stick coils to a G13BB with the standard ECU, has anyone on the forum done it, I'm thinking hotter spark?maybe?
19 Jul 2020 09:39 #225312 by Lambert
Replied by Lambert on topic Ignition coil help
As far as I am aware no one has done this. Probably because the standard ecu won't support it. Unless someone knows different?
19 Jul 2020 12:06 #225320 by Old Neil
Replied by Old Neil on topic Re:Ignition coil help
Lambert wrote: As far as I am aware no one has done this. Probably because the standard ecu won't support it. Unless someone knows different?
Thanks Lambert, I don't know technical side if the ECU can handle the extra load, just thought I'd ask, cheers
20 Jul 2020 08:33 #225382 by Riccy
Replied by Riccy on topic Re:Ignition coil help
I would doubt the standard ecu will have more than two coil drivers and how to modify the software i wouldn't know. Keithy is your man for coil-on-plug info as thats what hes using I believe...
I know the injectors are individually controlled (at least in a m series they are)
20 Jul 2020 09:16 #225385 by Old Neil
Replied by Old Neil on topic Re:Re:Ignition coil help
Riccy wrote: I would doubt the standard ecu will have more than two coil drivers and how to modify the software i wouldn't know. Keithy is your man for coil-on-plug info as thats what hes using I believe...
Thanks Riccy
20 Jul 2020 13:43 #225395 by Old Neil
Hi i re read your replys and not sure if i got my message across, I'm not wanting to drive the 4 coils individually but to keep it as the waisted spark system
I'm not clued up if the 4 separate coils would put a strain on standard ECU (ohms/voltage?)Sorry to be a pain
Time to create page: 0.159 seconds
