Winch help please
- Phattaff
19 Jul 2020 18:56 #225336
by Phattaff
Replied by Phattaff on topic Winch help please
The saga continues
Thanks for the diagram, but confused as the diagram doesn't show anything coming off the battery negative, so probably got it all wrong but used some jump leads and connected live to the live on the winch and the neg to the earth bolt on the side of the winch, nothing happened, also tried as per the diagram again nothing, is there an easy way to see if the motor actually works.
Phattaff
Phattaff
19 Jul 2020 19:58 #225349
by kirkynut
Replied by kirkynut on topic Winch help please
Get some jump leads with crocodile clips. Put the negative from the battery to the blue wire and the live to one of the other two wires on the motor. Which one you connect to just dictates which way the motor will go.
If nothing happens, the motor is not working and you'll have to take it off to see what the issue is.
If you just need a new motor, there are a few places that might be able to help:
www.electricwinchshop.co.uk/winch-access...-spares.html?cat=309
www.firstfour.co.uk/shop/winching-and-ac...mpion-warrior-parts/
- Phattaff
19 Jul 2020 21:24 #225364
by Phattaff
Cheers kirkynut
20 Jul 2020 07:49 #225379
by RainerK
Replied by RainerK on topic Winch help please
The negative in the picture goes where it says “Masse” or “Massepunkt” (grounding in English).
With Kirkynut’s description you test the motor and with the wiring diagram you also test the complete setup.
- Phattaff
20 Jul 2020 09:43 #225387
by Phattaff
Cheers again RainerK,
Will test the motor first then go from there.
Thank you to everyone who has helped me with this.
Phattaff
Phattaff
- Roger Fairclough
- Thank you received: 225
20 Jul 2020 12:02 #225392
by Roger Fairclough
Replied by Roger Fairclough on topic Winch help please
You may have inherited this winch because it stopped working and the main reason for this is that water has got in and the brushes have seized in the steel holders (probably) due to rust. Stripping a motor does not require an extensive tool supply or a degree in electrical engineering and there is enough knowledge on this forum to make the job a breeze.
Roger
Roger
